series 2 key ignition
wurzel
Main scooter: TV 175 / JET 200
Am I right in thinking that if I change a series 2 to key ignition I would have to use a TV 175 series 2 type and where would I get one or are there any other types that will fit. Would I also need the TV type light switch.
Cheers Mark
I would have thought that you could fit a Casa ignition switch. You can't fit the TV light switch and surround to an Li headset, the holes are in different positions. Li lower headset is different to a TV one.
DigDug
As corrado said you only need to use the switch as a kill switch with the green wire and not touch anything else.
Did you have to do that?
jason frost
Apart from the pink :)
Sent from my BlackBerry 9300 using Tapatalk
wurzel
Cheers folks
DigDug
jason frost wrote:Apart from the pink :)
It's been a while since I touched the pink.... ;)
squeakmillward
tipping the velvet :D only memories :D
jason frost
LOL
wurzel
last time I got me hands on the pink I accidentally touched it with the purple and it blew a fuse :shock:
thebassmasta
Main scooter: GP TS1 240
just wire it up the same a gp/li/sx use the ignition switch as your main switching, just isolate the wires on the handlebar switch for the lights, wire up the horn and dip switch, simples
