wiring diagram for sip speedo
Posted: Wed Mar 20, 2013 6:35 pm
by joespeed
can anyone supply this wiring diagram please?
Re: wiring diagram for sip speedo
Posted: Wed Mar 20, 2013 9:39 pm
by sideout
Posted: Thu Mar 21, 2013 11:07 am
by joespeed
i need to be more certain of the rev counter connections on the varitronic system,wheres sybil when you need her input!
Posted: Thu Mar 21, 2013 7:41 pm
by sideout
joespeed wrote:....wheres sybil when you need her input!
In Germany :?: ;)
The brown wire, which picks up the ignition pulses, is just connected to a 12V AC supply. The only thing you might have to adjust is the pulse number as I believe the Varitronic sparks twice as often as the usual 12V SIL type electronic ignition conversion.
