Best plates n springs
Posted: Fri Mar 15, 2013 11:00 pm
by wack 63
Using a PX/T5 7 spring clutch ,which clutch plates and springs would be a good choice for a Pinasco 225?
Re: Best plates n springs
Posted: Fri Mar 15, 2013 11:18 pm
by johnny rotten
Just used to use std plates n malossi springs on my old malossi 210 worked fine
Posted: Fri Mar 15, 2013 11:33 pm
by wack 63
I agree ,used them in the past on Malossis' just wondered if anything newer/better
Posted: Sat Mar 16, 2013 12:09 am
by johnny rotten
Harry Barlow uses them on his tuned engines so its got a proven track record sorry can't suggest anything else
Posted: Sat Mar 16, 2013 12:13 am
by wack 63
Ok thanks
Posted: Sat Mar 16, 2013 10:22 am
by roadrunnerian
i find malossi springs a bit stiff i use pinasco springs with a standard clutch on my t5 171 m8
Posted: Sun Mar 17, 2013 8:06 pm
by Juan
Not keen on Malossi springs myself, or at least not the whole lot. I'd use 4 Malossi and 3 standards if you can't get the DR ones. Not tried the Pinasco ones but they could be worth a try. Standard 3 plate is fine.
Posted: Sun Mar 17, 2013 9:15 pm
by goldeneye
3 plate , DR springs and a SIP spacer washer underneath the clutch is what I run ,no problems.
Posted: Mon Mar 18, 2013 10:51 am
by GLscoot
I've not used them but DRT and BGM are making clutches for the Vespa, but they are expensive.
Posted: Mon Mar 18, 2013 1:09 pm
by gimp1971
I bought some mallossi ones for my t5 but Diablo used some other ones as he said they are to stiff i will see him later so will ask
