sip speedo
Posted: Wed Mar 13, 2013 9:50 am
by smoore-gt225
hi ive done the mark the tyre and rolled along and it worked out at 1480mm, now all the threads ive read seem to be in the hi 1200mm to the low 1300mm, im running schwalbe racemans is anyone else getting hi measurements off these tyres
cheers steve
Re: sip speedo
Posted: Wed Mar 13, 2013 2:57 pm
by JINX
The number i had was around 1300.
To be more accurate, roll out 5-10 wheel distances, and then measure the total distance, and divide by the number of revolutions.
Perhaps your tires are just taller/bigger.
Re: sip speedo
Posted: Wed Mar 13, 2013 3:13 pm
by tonydevon
just stand it against a wall, preferably garage LOL or a bit of wood, cardboard etc sprit level on top of tyre, mark the height of the tyre, measure and mulitply by 3.14, simplest surely
Re: sip speedo
Posted: Fri Mar 15, 2013 10:49 pm
by corrado
Re: sip speedo
Posted: Sat Mar 16, 2013 12:30 am
by coaster
smoore-gt225 wrote:hi ive done the mark the tyre and rolled along and it worked out at 1480mm, now all the threads ive read seem to be in the hi 1200mm to the low 1300mm, im running schwalbe racemans is anyone else getting hi measurements off these tyres
cheers steve
You didn't mention what size tyre you are using, the Raceman comes in a variety of sizes and the 120/90 - 10 is 147.7cms, check what it says on the side wall, front tyre obviously
Re: sip speedo
Posted: Sat Mar 16, 2013 2:44 pm
by tonydevon
what speedo cable does the sip digi one take? indian or Italian?
Re: sip speedo
Posted: Sat Mar 16, 2013 11:51 pm
by sideout
tonydevon wrote:what speedo cable does the sip digi one take? indian or Italian?
Italian, Tony.
see:
http://scooterotica.org/forum/viewtopic.php?f=7&t=20931
