sip speedo
smoore-gt225
Main scooter: lambretta GT200
hi ive done the mark the tyre and rolled along and it worked out at 1480mm, now all the threads ive read seem to be in the hi 1200mm to the low 1300mm, im running schwalbe racemans is anyone else getting hi measurements off these tyres
cheers steve
JINX
The number i had was around 1300.
To be more accurate, roll out 5-10 wheel distances, and then measure the total distance, and divide by the number of revolutions.
Perhaps your tires are just taller/bigger.
tonydevon
Main scooter: '71 GP125
just stand it against a wall, preferably garage LOL or a bit of wood, cardboard etc sprit level on top of tyre, mark the height of the tyre, measure and mulitply by 3.14, simplest surely
Some tyre specifications here Steve ... http://www.savatech.eu/catalogues/sava- ... /26/zoomed
smoore-gt225 wrote:hi ive done the mark the tyre and rolled along and it worked out at 1480mm, now all the threads ive read seem to be in the hi 1200mm to the low 1300mm, im running schwalbe racemans is anyone else getting hi measurements off these tyres
cheers steve
You didn't mention what size tyre you are using, the Raceman comes in a variety of sizes and the 120/90 - 10 is 147.7cms, check what it says on the side wall, front tyre obviously ;)
tonydevon
what speedo cable does the sip digi one take? indian or Italian?
sideout
tonydevon wrote:what speedo cable does the sip digi one take? indian or Italian?
Italian, Tony.
see: http://scooterotica.org/forum/viewtopic.php?f=7&t=20931
