Std GP seat cover fitting.
Bombay Mix Pilot
Hi All, Need some guidance on the best way to fit a Std GP seat cover, I am asking as there are always some handy tips & hints on how to do it with good results, seems to be fighting me a little at the moment. This is reposted as it would seem the original post has disappeared.
Thanks in advance
Andy
Fighting you? I'm not quite sure how you can struggle to fit a seat cover I must admit. Plonk it on and bend the tabs into position. Isn't that all there is to it?
Bombay Mix Pilot
Hi, When I say fighting me what I mean is it's a new tight cover and I'm trying to get it fitted so the clips don't show when you look from the side etc. Also I'm curious about the best way people reckon on making seat strap holes in the cover for the strap bolts so they line up with the seat frame holes, spose just drill from the inside.
Andy
Doesn't sound right to me. You shouldn't be having that trouble. I'm not sure I'd start drilling. I think I'd get a nail and knock it through from the outside.
