mikuni tm34
AUSSIE
Can anyone tell me the differences between the tm34 and the tmx35.....and before anyone says bore size I'll get that in :D . I also know that the tmx is shorter in the body. mainly want if jets are compatable. Cheers
TM34 is a flat slide, TMX35 is a D slide. They both use the same main jets, type 4/042 and the same pilot jets, type VM22/210.
