A LIL TASTER
Posted: Sun Mar 03, 2013 7:32 am
SOMETHING COOKING IN THE GARAGE ~ GENUINE 1969 UK REGISTERED
~ SUPERLIGHT GP ~
FIBRE ~ Mudguard - Horn casting - Leg shields - Panels - Runner boards - Frame loop - Bridge - Toolbox door
Standard GP Plastics - Horn cover - Rear frame grill - Rear light - Petrol flap - Toolbox - Rear mudguard
200 Italian cast "Soon to be a ported 230 reed cast" ~ By DSConversion tuning
Engine ~ Internals & external lots of mb bitz n bobs
Tubeless rims ~ Got original Innocenti GP rims to fit
R1 shocker ~ Have an original SCM shocker to fit
Swopped the Regina for an Iwis duplex
Transmission - clutch etc GP innocenti
Af crank + Rd350 rod
One - off clutch plates - Brake shoes & Pads ~ Done by Adige-Ferodo "Courtesy of the brother in law" ~ Thank you John
12vac electronic ~ But will be 12vdc sooner than later
Innocenti ~ Reverse pull inboard disc
As normal will be swapping and changing as I go
22mm DELLORTO ~ ~ ~ REAMED TO 25.50 ~ CONVERTED CLUBBIE "IN THE BACKGROUND" ~ AWAITING VHT SPRAY
GENUINE SILME SEAT & CATCH ~ REFURBISHED WITH CASA COVER
HAVE AN ITALIAN INNOCENTI HEADSET TO FIT
ALL ORIGINAL 69 INNOCENTTI HEADSET FITTINGS - HEADLAMP - RIM -BULB HOLDER - STEERING LOCK - IGNITION - LIGHT SWITCH - BRAKE N CLUTCH LEVERS ETC ...
NOT SURE ABOUT KEEPING THE LD GLOVEBOX ~ THINK AN ORIGINAL INLINE WILL BE TAKING ITS PLACE
~ SUPERLIGHT GP ~
