A LIL TASTER
mnpes
SOMETHING COOKING IN THE GARAGE ~ GENUINE 1969 UK REGISTERED ;)
~ SUPERLIGHT GP ~
FIBRE ~ Mudguard - Horn casting - Leg shields - Panels - Runner boards - Frame loop - Bridge - Toolbox door
Standard GP Plastics - Horn cover - Rear frame grill - Rear light - Petrol flap - Toolbox - Rear mudguard
200 Italian cast "Soon to be a ported 230 reed cast" ~ By DSConversion tuning
Engine ~ Internals & external lots of mb bitz n bobs
Tubeless rims ~ Got original Innocenti GP rims to fit
R1 shocker ~ Have an original SCM shocker to fit
Swopped the Regina for an Iwis duplex
Transmission - clutch etc GP innocenti
Af crank + Rd350 rod
One - off clutch plates - Brake shoes & Pads ~ Done by Adige-Ferodo "Courtesy of the brother in law" ~ Thank you John
12vac electronic ~ But will be 12vdc sooner than later
Innocenti ~ Reverse pull inboard disc
As normal will be swapping and changing as I go
22mm DELLORTO ~ ~ ~ REAMED TO 25.50 ~ CONVERTED CLUBBIE "IN THE BACKGROUND" ~ AWAITING VHT SPRAY
GENUINE SILME SEAT & CATCH ~ REFURBISHED WITH CASA COVER
HAVE AN ITALIAN INNOCENTI HEADSET TO FIT
ALL ORIGINAL 69 INNOCENTTI HEADSET FITTINGS - HEADLAMP - RIM -BULB HOLDER - STEERING LOCK - IGNITION - LIGHT SWITCH - BRAKE N CLUTCH LEVERS ETC ...
NOT SURE ABOUT KEEPING THE LD GLOVEBOX ~ THINK AN ORIGINAL INLINE WILL BE TAKING ITS PLACE
DigDug
Very nice.
Is there anything special about a "real 22mm Dellorto"?
Did you have to do that?
mnpes
DigDug wrote:Very nice.
No ~ there are better carbs :frog:
Very nice :D
Seems a pity to sacrifice an original carb really. Surely you could put a new one on there?
mnpes
Doom Patrol wrote:Seems a pity to sacrifice an original carb really. Surely you could put a new one on there?
A bit of nostalgia for me ~ one of my fist AF"s in the 70"s had a reamed delly and 50mm baffless clubbie on
When the reedblock goes on ~ A genuine Keihin pwk28 will be fitted ~ As is on the other gp ~ "They run sweet"
Won"t use the Italian cylinder or head either ~ When reedblocked
Indian cylinders are harder wearing ~ I prefer them when boring to 71.00mm
Will be using an AF high compression head ~ Quality at a good price
vegansydney
How does the Casa seat cover fit on the SILME seat frame?
A pig to fit 2 of the fold up tabs? Ask me how I know? :oops:
When I was in Italy recently I found out from a very reliable source that Casa GP covers are designed for the Giuliari coffin seats not the SILME seats. The SILME seat covers originally only had 5 tabs per side not the 6 that Casa for one has making it a pig to fit the SILME frame.
PS: love a GP200 in white.
mnpes
vegansydney wrote:How does the Casa seat cover fit on the SILME seat frame?
Luckily enough the fitting wasn"t done by me ~ I acquired the seat refurbished ~ After some haggling ~ It"s a quality job
I will pop a few pictures of the seat on later ;)
mnpes
Blistered Baz
Main scooter: Lambretta Li150 S 1964
Ahhh, that answers a qustion that I've had for a while. I've got an original (well, i think it is as it's all rusty!!!) giuliari seat on my 64 LiS and it desperately needs a recover.
So, casa do one that just pops on with the tabs??
