Page 1 of 2
PX rear hub conversion
Posted: Sun Feb 24, 2013 8:24 pm
by djh66
I'm in the process of coverting a px engine to 8" rear hub to put in mates Sportique, using SIP's conversion kit
http://www.sip-scootershop.com/en/main/ ... r=50015160 however I can't get the hub on, over the supplied brake shoes! Any ideas?
Re: PX rear hub conversion
Posted: Mon Feb 25, 2013 10:11 pm
by djh66
Were/ are there different rear brake cams fitted, with different width of cams (just wondering if the cam is slightly too wide, pushing the shoes out too far)?
Posted: Tue Feb 26, 2013 4:40 pm
by GLscoot
Why?
The dust plate and the shoes have to change to 8". I've not done this conversion.
Posted: Tue Feb 26, 2013 5:16 pm
by Donnie
Dave could it just be that there's a few high spots on the new shoes that need a chamfer?
Posted: Tue Feb 26, 2013 7:39 pm
by djh66
Donnie wrote:Dave could it just be that there's a few high spots on the new shoes that need a chamfer?
Apparantly, speaking to those ITK, I have to grind a couple of mm of the end of the shoes, that make contact with the cam, this should then allow the hub to go on.
Posted: Tue Feb 26, 2013 7:41 pm
by Donnie
eh?? off the actual face of the shoe that makes contact with the cam???
Posted: Tue Feb 26, 2013 8:44 pm
by djh66
Donnie wrote:eh?? off the actual face of the shoe that makes contact with the cam???
No, no, no...the end of the shoe, that makes contact with the cam
Posted: Tue Feb 26, 2013 9:48 pm
by Donnie
As in ........
Posted: Tue Feb 26, 2013 11:10 pm
by djh66
Yes that's correct. Done that tonight, hub now fits over brake shoes :anbrgin; However, this is where I encounter the next problem
The 8" hub now rubs on the brake shoe pivot pins! They don't tell you things like this when you buy products, I expect better from SIP. I suppose I'll have to skim some ally of the pins so they clear the hub.
Posted: Wed Feb 27, 2013 1:08 am
by Donnie
I wouldn't have even been happy taking metal off the shoe as you've had to do to be honest
I certainly dont think id be taking metal off the pivot pins especially as then you'll probably have no metal left for the cirlips :-/
