Page 1 of 4
casa gp wont start
Posted: Sun Feb 17, 2013 5:45 pm
by weedodger
iv just went to fire scoot up after winter, and it wont go,
changed plug, took carb to bits, no joy fuel going through when tap open,
drained petrol from tank, lots of tiny debris in it, stainless tank i have, so put new fuel in, nothing, great spark, it goes to fire up, sometimes it will idle a few secs, then die.
It ran great all last year, timing maybe? i have elec ign and a rewound stator, which has been great,
Re: casa gp wont start
Posted: Sun Feb 17, 2013 6:12 pm
by mick1
clogged fuel tap ?
Posted: Sun Feb 17, 2013 6:28 pm
by weedodger
mick1 wrote:clogged fuel tap ?
iv ordered a new fast flow one, , will go and drain whats in tank after i eat,clean it if i can, and have another go,
cheers
Posted: Thu Feb 21, 2013 10:59 pm
by weedodger
Changed fuel tap for new, plug, swapped carbs, very hesitant to start, does start, but dies quickly.
What can i check next, in order of probability please.
Posted: Fri Feb 22, 2013 8:13 am
by dutch
if it will run on tickover just let it warm up for a bit before giving any throtle, i have one thats like that when cold.
Posted: Fri Feb 22, 2013 10:50 am
by roadrunnerian
what carb have you got fitted if standard check filter where the petrol goes into carb .
Posted: Fri Feb 22, 2013 11:44 am
by weedodger
All styles jetex,set up for the kit,cheers
Posted: Fri Feb 22, 2013 12:17 pm
by Doom Patrol
Couldn't get mine to start either, and that's fitted with a Casa kit. Mind you that was weeks ago and I shoved it back in the garage and left it. I must look at it sometime.
Posted: Fri Feb 22, 2013 9:14 pm
by weedodger
right, i cant find my flywheel removal tool, but one of the windings looks burnt, the one at around 11 oclock on the stator,, will have a look tomorrow once i find the flywheel puller.
Posted: Fri Feb 22, 2013 11:13 pm
by Doom Patrol
What stator is it?
