casa gp wont start
weedodger
Main scooter: Indian gp casa 185 and 200
iv just went to fire scoot up after winter, and it wont go,
changed plug, took carb to bits, no joy fuel going through when tap open,
drained petrol from tank, lots of tiny debris in it, stainless tank i have, so put new fuel in, nothing, great spark, it goes to fire up, sometimes it will idle a few secs, then die.
It ran great all last year, timing maybe? i have elec ign and a rewound stator, which has been great,
mick1
Main scooter: Li Avanti 225
clogged fuel tap ?
weedodger
mick1 wrote:clogged fuel tap ?
iv ordered a new fast flow one, , will go and drain whats in tank after i eat,clean it if i can, and have another go,
cheers
weedodger
Changed fuel tap for new, plug, swapped carbs, very hesitant to start, does start, but dies quickly.
What can i check next, in order of probability please.
dutch
if it will run on tickover just let it warm up for a bit before giving any throtle, i have one thats like that when cold.
roadrunnerian
what carb have you got fitted if standard check filter where the petrol goes into carb .
weedodger
All styles jetex,set up for the kit,cheers
Couldn't get mine to start either, and that's fitted with a Casa kit. Mind you that was weeks ago and I shoved it back in the garage and left it. I must look at it sometime. :lol:
weedodger
right, i cant find my flywheel removal tool, but one of the windings looks burnt, the one at around 11 oclock on the stator,, will have a look tomorrow once i find the flywheel puller.
What stator is it?
