Disabling autolube
djh66
Main scooter: 150 special
Hi all, I'm putting a px engine into a mates Sportique, obviously, I need to disable the autolube, but whats the best way to do this? Cheers Dave
Bring Me Sunshine COYH
goldeneye
pull the pipe off and put some 2 stroke in the petrol tank...... :lol: i usually pull the box off, pull the oil pump shaft out, and fill the hole with some black mastic, or builders adhesive, something like that. you can remove the pump totally if you like. if you want to go back to autolube, just cap off the oil feed tube, and mix in the tank as normal. put an "X" in marker pen or tape, on top of your petrol tank to remind you to put oil in the tank until you get used to doing it 2nd nature.
djh66
goldeneye wrote:pull the pipe off and put some 2 stroke in the petrol tank...... :lol: i usually pull the box off, pull the oil pump shaft out, and fill the hole with some black mastic, or builders adhesive, something like that. you can remove the pump totally if you like. if you want to go back to autolube, just cap off the oil feed tube, and mix in the tank as normal. put an "X" in marker pen or tape, on top of your petrol tank to remind you to put oil in the tank until you get used to doing it 2nd nature.
Mate's Sportique, so he's used to premixing. Do i need to do anything to the oil inlet of the autolube carb?
goldeneye
no. you could remove carb and use a sealant between it and the box for piece of mind, but its not really needed. done loads by just blocking the pipe and mixing in the tank. dont like autolubes me.
djh66
Excuse my ignorance :? Would not the oil inlet tube on the carb draw air through it if not blanked aswell?
goldeneye
youve already blanked the pump off, so shouldnt be drawing air from anywhere.
djh66
goldeneye wrote:youve already blanked the pump off, so shouldnt be drawing air from anywhere.
Ah, I see, thanks
Yanker
Disconnect the pump mechanical drive (so it does not seize)
and
Block the oil delivery passage to the carb (so that it does not draw air.)
Simples :)
