Page 1 of 2
Dellorto phbl 22
Posted: Sat Feb 09, 2013 8:29 pm
by bishopsfinger
Hi all! Can I ask the forum why the 22mill phbl carb isn't used widely?
Re: Dellorto phbl 22
Posted: Sat Feb 09, 2013 8:58 pm
by Boothy_the_makem
I dunno. is it cos they are quite rare now ?
Ive just given one away :)
Posted: Sat Feb 09, 2013 9:01 pm
by Yanker
In the Lambretta forum mode:
1) As the body is the same size as the 24mm and 25mm versions, so foir the outlay on carb manifold rubber, clips, cables jets and needles to dial in, there is less 'improvement in performance' ie it is the same size as a standard fitment Lambretta carb, with less expense and less hassle.
2) Supplyand Demand - They do not seem to be as readily available or as well promoted or documented as the larger PHBLs. (Also true for other 'modes')
In Vespa mode:
1) Have used one as part of a Vespa Smallframe 135cc induction, as one was available at the right price and suited to complement the up-grade.
In General mode:
1) Nothing wrong with them mind
Posted: Sat Feb 09, 2013 9:03 pm
by bishopsfinger
Hmm it's just that I'm stalking one on eBay and you never here them talked about,I'm not a fan of big carbs and I thought this might be a good compromise,the other thing is someone told me that they will fit on a standard 22 manifold or is that bolo?-
Posted: Sat Feb 09, 2013 9:27 pm
by Boothy_the_makem
I think you have to watch out for indian lambro ones which are slightly different. someone will put me right on this :)
Posted: Sat Feb 09, 2013 10:15 pm
by rosscla
PHBL is a round slide dellorto carb like the PHBH but smaller...are you thinking of the JETEX sh2/22??
Posted: Sun Feb 10, 2013 1:39 am
by bishopsfinger
I'm definatley talking about the round slide carb
Posted: Sun Feb 10, 2013 2:22 am
by rosscla
bishopsfinger wrote:I'm definatley talking about the round slide carb
Yes but I'm not sure boothy is
Posted: Sun Feb 10, 2013 3:14 am
by Boothy_the_makem
I'll get my coat :D
http://www.mbdevelopments.co.uk/lambretta/lt10.html
Posted: Sun Feb 10, 2013 12:06 pm
by byron
is it rubber mounted then ?
the only 22PHBL carbs I have seen are solid mount
then we had issues finding a manifold that would put the carb in the right place to use the oe airbox, not helped by having the scoop on the cylinder cowling.
I think they could be a good alternative to a worn out dellorto, or less than precision-made jetex, but the manifold could be the issue...
Jet200 supply inlets ~ http://jet200.com/catalog/product_info. ... ts_id=1407
but with postage and maybe some import duty it's a fair whack to try a carb out.
will probably end up getting two manifolds cut and shut...
