Dellorto phbl 22
bishopsfinger
Main scooter: vespa gl177
Hi all! Can I ask the forum why the 22mill phbl carb isn't used widely?
Boothy_the_makem
Playstation gamer tag: Phantomkiller_uk
Main scooter: modded t5 classic wi a parker
I dunno. is it cos they are quite rare now ?
Ive just given one away :)
Canny lass, Geordie girl, he gave her pints and fags and grub and shorts. Canny lass, Geordie girl, she gave him earache and penal warts,Penal warts.
Yanker
In the Lambretta forum mode:
1) As the body is the same size as the 24mm and 25mm versions, so foir the outlay on carb manifold rubber, clips, cables jets and needles to dial in, there is less 'improvement in performance' ie it is the same size as a standard fitment Lambretta carb, with less expense and less hassle.
2) Supplyand Demand - They do not seem to be as readily available or as well promoted or documented as the larger PHBLs. (Also true for other 'modes')
In Vespa mode:
1) Have used one as part of a Vespa Smallframe 135cc induction, as one was available at the right price and suited to complement the up-grade.
In General mode:
1) Nothing wrong with them mind
bishopsfinger
Hmm it's just that I'm stalking one on eBay and you never here them talked about,I'm not a fan of big carbs and I thought this might be a good compromise,the other thing is someone told me that they will fit on a standard 22 manifold or is that bolo?-
Boothy_the_makem
I think you have to watch out for indian lambro ones which are slightly different. someone will put me right on this :)
PHBL is a round slide dellorto carb like the PHBH but smaller...are you thinking of the JETEX sh2/22??
bishopsfinger
I'm definatley talking about the round slide carb
bishopsfinger wrote:I'm definatley talking about the round slide carb
Yes but I'm not sure boothy is
Boothy_the_makem
I'll get my coat :D
http://www.mbdevelopments.co.uk/lambretta/lt10.html
is it rubber mounted then ?
the only 22PHBL carbs I have seen are solid mount
then we had issues finding a manifold that would put the carb in the right place to use the oe airbox, not helped by having the scoop on the cylinder cowling.
I think they could be a good alternative to a worn out dellorto, or less than precision-made jetex, but the manifold could be the issue...
Jet200 supply inlets ~ http://jet200.com/catalog/product_info. ... ts_id=1407
but with postage and maybe some import duty it's a fair whack to try a carb out.
will probably end up getting two manifolds cut and shut...
