Dyno set up at replay scooters
simonwwfc
I'm taking mine to chalkie at replay scooters tomorrow to be set up on dyno should I notice much difference or is it just a piece of mind to no it will be running rite
We have no way of telling, let us know how it goes though.
You'll have the peace of mind that on that day and on that dyno the readings and jetting were set up correctly and hopefully safely. You'll also get the benefit of someone with a lot of experience setting scooters up.
If you're lucky you might you might be able to get an improvement performance.
simonwwfc
Well it's had a few changes 28mm dellorto and sterling exhaust since I've owned it just hoping they get it to pull better
Agree he will get it set up right it may be the gearing causing it not to pull to its full performance
simonwwfc
Toddy wrote:Agree he will get it set up right it may be the gearing causing it not to pull to its full performance
If its the gearing wot sort of job is this to improve it and what's reqd
Might be as simple as changing the front sprocket up or down a tooth to get the best out out of your carb and pipe, but could just as easily mean a complete change of drive train to get suitable ratios.
Do you know what sprockets and gearbox are in it now?
If you know what gearbox and sprockets you have in it you need to define what ratio you need to get the best out of your bike with the carb and pipe you have fitted plus suiting it to the type of riding you do
Have a look here the gear chart from AF Rayspeed it will help in your set up
http://www.afrayspeed.co.uk/pages/45-to ... -chart.xls
Hope this helps I'm sure when you take it for dyno he will advise you if he sees it as an issue
Wayne Miller
simonwwfc wrote:I'm taking mine to chalkie at replay scooters tomorrow to be set up on dyno should I notice much difference or is it just a piece of mind to no it will be running rite
How did you get on, did Chalkie put it right for you?
Stay tuned..............
simonwwfc
Over at chalkie this morning around 10 ish . Haven't got a clue. Wots in it gp125 with 175 barrel and head gonna try and get hold of chap who built it
tonydevon
Main scooter: '71 GP125
I would really appreciate it if you could post up info and your thoughts on the day and process, Im planning on getting mine run in, then hiring a van for the day and going for a dyno session to get it setup right, cant afford to build it again
would like to know what they do, never been to a dyno session
