Vega legshilds
Rothbard
Main scooter: Lambretta Li 190
I'm attempting to make a set of Vega style legshields and need to know what's the typical way these thing get attached onto the fork tube. I've seen pictures of the carbon fiber ones that don't seem to have any bolts or straps up at the top of them . Are they just so stiff that they stay in place at the top once they are bolted to the floor struts? Image
tony172
Main scooter: vespa t5
mate i dont know the answer to your question, but that looks f****n cool :)
Rothbard wrote:I'm attempting to make a set of Vega style legshields and need to know what's the typical way these thing get attached onto the fork tube. I've seen pictures of the carbon fiber ones that don't seem to have any bolts or straps up at the top of them . Are they just so stiff that they stay in place at the top once they are bolted to the floor struts? Image
No...they have to be bolted on at the headstock. Metal vega leggies have a bracket, but fibreglass and carbon one dont....you have to fab something.
RobD
Mine have a c shaped bracket welded to the inside of the legshields and a horizontal tube welded to the front of the head tube about 6 inches down from the top. The legs of the bracket are the same width apart as the length of the tube (+ a couple of mil) and then a long bolt goes through the bracket and tube holding them on.
wack 63
Main scooter: '71 GP TS1
This is how I did mine ,the bracket is on the Vega shields and then I welded a threaded tube to the frame Image
Rothbard
Thanks for the info.
wack 63 wrote: Image
like the damper :D
mine are the fibre ones and bolt straight to a plate at top of headstock ..
one question though .. why make the leggies ??
like the damper :D
also the frame loop and side panels ?
    Users browsing this forum: Semrush [Bot] and 14 guests
