Agusto?
ArmandTanzarian
Variable timing modules are very common on Lambrettas but do they bring much benefit to PX engines?
chrisM
Main scooter: Vespa GS 200
I would like to know this as well!
Especially, would be there any benefit on a bog standard, untuned P200 engine (with Sito +)??
goldeneye
i run the 6000 on my P200, a bit crisper low down, but the main thing is ive noticed i get more MPG.
roadrunnerian
better at starting and more power low down the rev range can't about say about mpg the throttle is always wide open m8
chrisM
Do you have to alter the ignition timing when fitting the Agusto or just leave it standard?
bsso78
August 2012 edition of Scootering has the information on how to set up a Vespa to use an Agusto or Chiselspeed MTech.
