Innocenti cylinder
Posted: Sun Jan 20, 2013 10:53 pm
by Hotdog
Did any manufacture or anyone else copy or produce a 200 cylinder with two notches in top fin and a numbered lump/boss by the inlet port other than Innocenti ? the reason i ask is i have a cylinder as described but can't read a number (worn away), can i be certain that this made by Innocenti ?
Re: Innocenti cylinder
Posted: Sun Jan 20, 2013 11:07 pm
by Adam_Winstone
Others copying the cylinder did copy over the notches.... a great example being the TS1 kit, However, I can't immediately think of any that coppied over both the notch and number stub, although I hav eit in the back of my mind that I might have seen cylinders with a blank stub, which might be indicative of copies.
Hopefully someone can tell you for sure.
Adam
Posted: Mon Jan 21, 2013 12:42 am
by Stokie
Wasn't there something about pattern cylinders in Stickys book?
Posted: Mon Jan 21, 2013 6:14 am
by DigDug
Are they worth anything?
I've had one lurking in a chest since 1976!
