Innocenti cylinder
Hotdog
Did any manufacture or anyone else copy or produce a 200 cylinder with two notches in top fin and a numbered lump/boss by the inlet port other than Innocenti ? the reason i ask is i have a cylinder as described but can't read a number (worn away), can i be certain that this made by Innocenti ?
Others copying the cylinder did copy over the notches.... a great example being the TS1 kit, However, I can't immediately think of any that coppied over both the notch and number stub, although I hav eit in the back of my mind that I might have seen cylinders with a blank stub, which might be indicative of copies.
Hopefully someone can tell you for sure.
Adam
Stokie
Wasn't there something about pattern cylinders in Stickys book?
DigDug
Are they worth anything?
I've had one lurking in a chest since 1976!
Did you have to do that?
