Lambretta Disc Brake Hydraulic ANTI - DIVE Disk Disc Kit
Spud
Any one using one of these?
http://www.ebay.co.uk/itm/Lambretta-Dis ... 2ec5008de2
Are they any good?
cheers
Spud
joeswoonara
Main scooter: jet ts1
yes i`ve got one on my s2 ....use it with a concealed master i really like .....and a lot safe than a 40/50 yr old backplate :shock: imho
That's a HUGE amount of money.
This is about the same price. Admittedly, you'd need a hose and a master cylinder, but you'd probably replace those anyway with one from the far east. And, it's tubeless.
Minority
Main scooter: Li230 S3
Works really well, I've just fitted the anti dive update to mine and that was really worthwhile. A lot of people in our club, PLSC, use them. Also available from justlambretta.com who is renowned for good service and good prices for forum members.
rbgaz
Minority wrote:Works really well, I've just fitted the anti dive update to mine and that was really worthwhile. A lot of people in our club, PLSC, use them. Also available from justlambretta.com who is renowned for good service and good prices for forum members.
hi is that a newer version of the tie bar on your scootsrs anti dive ?
Minority
No, just a little mod coz I thought it looked sexier :D
I'd seen something similar on a couple of forums so I thought I would give it a go.
The rose joints I used are much better quality than the ScootRS ones, but will it make any difference to how well it works, I don't think so :lol: .
Parts used cost about 10 quid:
http://www.ebay.co.uk/itm/M8-Female-Ros ... 0796576064?
http://www.ebay.co.uk/itm/M8-x1-25mm-Ma ... 0884700715?
Does look great..might change mine for a £10 any other mods needed or just straight bolt on?
Minority
Andy Pickering wrote:Does look great..might change mine for a £10 any other mods needed or just straight bolt on?
Yes Andy, it is a straight bolt on replacement (for my kit). Just needs the two rose joints as linked, plus an 8mm nut to lock up when adjusted. I think you should treat yourself!
Yes Andy, it is a straight bolt on replacement. Just needs the two rose joints as linked, plus an 8mm nut to lock up when adjusted. I think you should treat yourself!
is that one male thread and one female rose joint ?
Minority
Yes, exactly as linked:
The male just screws into the female (so to speak :D ) and is locked with an 8mm nut.
Cheers, John
    Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 11 guests
