how good would this set up be (on a t5)
Posted: Mon Dec 31, 2012 3:01 pm
by soulboy
dont think my budget would stretch to a malossi motor ..so im wondering what the performance (and reliability ) on this set up ...polini 152 stock carb with casings mated to it 21 tooth cosa clutch banded and pm pipe ... will only be used for long distance work cheers
Re: how good would this set up be (on a t5)
Posted: Mon Dec 31, 2012 5:20 pm
by gimp1971
PM pipes for T5 are crap 21 tooth ok if you have long straights if not keep as 20 tooth alot more fun
Posted: Mon Dec 31, 2012 7:15 pm
by soulboy
yea mate i no all that but as for the pm with stock top end.. and 20 tooth clutch it pulled like a train all through the gears... what i realy need to no is ....would i notice a lot of differance between stock top end and a polini kit
Posted: Mon Dec 31, 2012 8:54 pm
by roadrunnerian
keep your clutch standard with 20 tooth and i would use a torquey pipe because the kit is tuned for torque.i'm changing back to a 20 tooth from a 21 they are ok if you are doing motorway work you loose the quick off the mark of the t5
