Mallossi 210 Tune - 23.5bhp & 18.5ft-lbs - Touring Tune
Posted: Mon Dec 10, 2012 11:17 pm
by drunkmunkey6969
Mallossi 210 kit - Scooterotica porting spec to Cylinder & Casings (Touring Tune)
28mm Delly
JL3 RH Pipe
Reed Valve Conversion
Scooterotica Gas Flowed/Cut crank
Steady power starting from just over 4200rpm through to 8000rpm.
Peaks at 23.5bhp - with rich jetting (AV266 & 138 main) on a little 28mm carb. Over 25bhp should be easily achievable with a 30mm Delly and 135 main, but leaves less room for temp changes, so happy with this nice touring set up. Good power at low to mid revs.
Re: Mallossi 210 Tune - 23.5bhp & 18.5ft-lbs - Touring Tune
Posted: Mon Dec 10, 2012 11:48 pm
by Nyle
What type of port timings are you running on your transfers and exhaust
Posted: Tue Dec 11, 2012 2:09 pm
by drunkmunkey6969
Nyle wrote:What type of port timings are you running on your transfers and exhaust
What type? really nice touring ones.....
Posted: Wed Dec 12, 2012 6:30 pm
by Spanish Fly
Dan.
Do your "Touring Tune" porting mods give more bottom end power than a standard Mallossi?
Cheers.
SF
Posted: Wed Dec 12, 2012 8:41 pm
by drunkmunkey6969
Yes. Ill find some 'common' 210 graphs and see if i can get them uploaded to compare.
210s are very peaky and lacking in mid range in my opinion, we tackle that problem with this tune.
Posted: Thu Dec 13, 2012 9:16 pm
by Spanish Fly
drunkmunkey6969 wrote:Yes. Ill find some 'common' 210 graphs and see if i can get them uploaded to compare.
Yeah good. Should make an interesting comparison.
SF
Posted: Thu Dec 13, 2012 11:23 pm
by sean brady scooters
Spanish Fly wrote:drunkmunkey6969 wrote:Yes. Ill find some 'common' 210 graphs and see if i can get them uploaded to compare.
SF
can you also provide some of your results also ...interesting to compare and discuss
