28mm Delly
JL3 RH Pipe
Reed Valve Conversion
Scooterotica Gas Flowed/Cut crank
Steady power starting from just over 4200rpm through to 8000rpm.
Peaks at 23.5bhp - with rich jetting (AV266 & 138 main) on a little 28mm carb. Over 25bhp should be easily achievable with a 30mm Delly and 135 main, but leaves less room for temp changes, so happy with this nice touring set up. Good power at low to mid revs.
