New BGM largeframe clutch
chrisM
Main scooter: Vespa GS 200
Did anybody fit that clutch so far and is it good?
Curious, Chris
GLscoot
Main scooter: Vespa GS150
Is it the one that costs £200.
Clutch -BGM Superstrong (made in Germany) CNC machined, 10-springs, Cosa2 type- Vespa Cosa2, PX (from 1995) - 20 teeth
item number BGM8096
The BGM PRO Super Strong Cosa clutch is a great plug and play solution - Made in Germany. You get a ready to mount clutch with the included uprated clutch springs which works fine in a power range up to 20hp / 22Nm.
With separately available stiffer springs*, the clutch won’t let you down even with setups over 30 hp.
Features:
One-piece CNC machined clutch basket - Made in Germany.
The extremely robust design with a revolutionary hub offers a perfect and precise control
The hub is made of high-strength steel so that cracking of the hub is prevented.
The use of ten springs is designed for high torque setups with low effort at the lever.
Nitration hardened clutch basket, so worn out clutch baskets are history.
Thanks to the pressed sintered bush you always have accurate separation of your clutch.
Each clutch is subjected to quality control. Thus we assure you that we provide a working and ready to install clutch.
The delivery of the complete clutch includes the ready to mount clutch with bgm PRO Cosa clutch plates, a new woodruff key, a suitable clutch nut and an O-ring for the clutch cover.
_________________________________________________________________________________
TECH TIPs:
The number of teeth of the clutch is important for the length of the total reduction. It can also be varied. Possible combinations:
Original 20 teeth: 21T, 22T
Original 21 teeth: 20T, 21T, 22T
Original 22 teeth: 20T, 21T, 22T
Original 23 teeth: 21T, 23T
For models up to 150cc it is necessary to remove the small cast aluminum nose in the engine casing in order to mount the clutch. This can even be bent very simple with a large plier. With some clutch covers the drip nose in the area of the radius has to be removed slightly.
The clutch can be mounted in all large frame Vespas. These are all vehicles whose FIN number starts with minimum three charakters at the beginning (e.g. VNB, VNL, VNX, ZAPM etc., the extra 1T, 2T, 3T is not considered) and which have the carburetor directly installed to the crankcase (not in frame or on the cylinder). Some old vehicles before the PX era with the thin washer (1.5 mm) below the clutch have to be exchanged against the PX models (3.3mm/item number 7671297).
GLscoot
What does this bit mean. I have no idea what they are talking about.
Gary
ArmandTanzarian
This mentions removing noses and even has pictures
http://blog.scooter-center.com/2012/08/ ... x/?lang=en
chrisM
Yes, that's the one I was thinking of.
Did anybody fit this clutch already?
Cheers, Chris
GLscoot
From the picture on the blog. Is it a case of grinding away the section marked red. It does not mention anything about the plunger or pressure plate, I take it that the standard parts can be used.
Gary
GLscoot
I'm also looking at there PX rear shock at £180, clutch £200. Crank £149, carb set up £200, Polini 180 kit £180 and Pinasco flywheel kit £240. Standard gears and primary. This engine has cost a bloody fortune, it better be worth it.
I have not used or bought the clutch, but I think I will. Just hope my Christmas tips are good this year.
Gary
ArmandTanzarian
I must admit, the clutch is tempting. Even with a standard P2 engine I've struggled with knackered standard clutches and poor quality, pattern cosa ones. If I can fit and forget about it it'll be worth the cash
chrisM
GLscoot wrote:I'm also looking at there PX rear shock at £180, clutch £200. Crank £149, carb set up £200, Polini 180 kit £180 and Pinasco flywheel kit £240. Standard gears and primary. This engine has cost a bloody fortune, it better be worth it.
Gary
Gary, if you order in December everything will be 20% off...
GLscoot
From SIP or Scooter Center.
Gary
    Users browsing this forum: No registered users and 54 guests
