Mec 60mm crankshaft replacement con rod ???
Posted: Tue Dec 04, 2012 9:12 am
by ssteam177
I need to replace the snapped rod on mec 60mm with 107mm rod.
Which one do I use that will hold together on this set up
Monza 225
Gp 200 gearing std
Tmx 35
Vari
Jl4
I was happy with this set up untill the crank failed, but this time I'd like to add some v force reeds and the lth 7 plate clutch that I have sitting here
Thankyou in advance for any advice given
Re: Mec 60mm crankshaft replacement con rod ???
Posted: Tue Dec 04, 2012 10:38 am
by drunkmunkey6969
Buy a Yamaha 110mm rod and use a 3mm packer plate.
