Mec 60mm crankshaft replacement con rod ???
ssteam177
Main scooter: vba malossi 221, api series2
I need to replace the snapped rod on mec 60mm with 107mm rod.
Which one do I use that will hold together on this set up
Monza 225
Gp 200 gearing std
Tmx 35
Vari
Jl4
I was happy with this set up untill the crank failed, but this time I'd like to add some v force reeds and the lth 7 plate clutch that I have sitting here
Thankyou in advance for any advice given
IT'S NOT WHAT YOU BUY
IT'S WHAT YOU BUILD!!!!
Buy a Yamaha 110mm rod and use a 3mm packer plate.
