t5 vespa 172 kit
mick fletcher
Main scooter: vespa t5
all of a sudden started back firerin changed plug looked in carb any ideas
cezeta
if you de exelerate then open the throttle does it back fire then?
Badwolfli225
Main scooter: LI150 Runabout
Woodruff key?
cit205
Water in CDI ? Take the rubber boot off and have a look , if it's wet don't use wd40 just dry it out. Spraying wd40 everywhere can cause shorts too.
cezeta
my back firing was first a drive side seal faulure air leak, then a carb rattling loose air leak, then an exhaust downpipe crack air leak.
3 separate problems with similar symptoms.
