Winter/rallymaster mudguard brackets
sydduckett
Anyone know where you can get the u shaped brakets that fit between the forks and the insides of the mudguard. I have only seen the ones that are welded onto the forks, these would do but ones that clip round the forks would be better if such a thing exsists...... :D
Ta
Sef
clyde
PM sent.
sydduckett
Still looking for these. Anyone point me in the right direction or have a spare set to sell... ;)
ta
sydduckett
Anyone point me in the right direction on these brackets that attach the forks to each side of the turning mudguard. I think I have seen a pic somewhere and they are u-shaped peices of metal with a thread welded on to take the mudguard?
If these are still not avaialble then a pic would be good as i should be able to get something fabricated.
Also I have the clamp for where the forks go through the top of the mudguard. Is all there is for this area and is it simply a case of placing it just above the dust cover and tightening up? The forks are off a Indian series 2, are ther any other mods/bits I will need to get the spanish mudguard to work correctly on an indian series 2?
Thanks
Sef
Donnie
Yea, the brackets are no more fancy than a bit of U shaped metal with a hole in to put a 6mm bolt through and a nut the other side.
As for the bracket on top of the forks / dust cover, the forks are specific I thought to the spanish variety, unless there is a conversion Im unaware of, in which case someone will be along. But you cant simply whack in some indian forks or italian forks if you see what I mean?
Donnie.
smoore-gt225
Main scooter: lambretta GT200
hi buzzsolomoto is probaly your best bet http://www.buzzsolomoto.com/
and you have to remove the dust cover on the frame for the mudguard to fit
cheers steve
A collar will need welding to the forks for the muduard to clamp on to, as far as the side brackets are concerned, I hope this helps...
Courtesy of Cobby ;)
the collar as far as i am aware is the same section as the frame tube
sydduckett
soulsurfer wrote:A collar will need welding to the forks for the muduard to clamp on to, as far as the side brackets are concerned, I hope this helps...
Cheers for that couldnt really ask for more....... :D
gaz_powell
^^^^^ thats a great picture^^^^^^
Im just about to start the same - i have italian forks so i`m in the same boat as you -i`m intending to use a fibreglass mudguard - dont collect my forks til next week and just order the mudguard
Syd
keep us updated with pictures on how you are getting on
Soulsurfer
have you do this conversion - just wondering how deep the collar is ?
gaz
