Vespa RB250
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
I was wondering if its possible to fit an RB250 kit on a Vespa?
Just a thought... Any ideas on crank etc
Cheers Russ :fb:
jonny snatchsniffer
why ? get a smallframe and falc it, im sure if falc had done a decent kit for a p range oz wouldnt have fitted a ts1 to a t5 motor
but since you ask anything is possible if you have the money
dopeshots
Main scooter: GP150
jonny snatchsniffer wrote:why ? get a smallframe and falc it, im sure if falc had done a decent kit for a p range oz wouldnt have fitted a ts1 to a t5 motor
Well I have never heard of anyone doing an RB250 so thought I'd ask the question...... ;)
OzOAP
Main scooter: Vespa PTS1E
I looked into it, got hold of a shagged cylinder and I have a set of T5 casings ready and waiting.
When I did the PTS1E, I used a 120mm con-rod and had to take 7mm off the bottom of the TS barrel.
Due to the inlet port on the RB, is isn't possible to take 7mm off the bottom.
I looked around for a longer (125mm+) rod but couldn't find one, so gave up on the idea.
dopeshots
Main scooter: GP150
Well that answers that lol.. thanks for letting me know ;)
Darrell Taylor
Main scooter: LAMBRETTA
OzOAP wrote:I looked into it, got hold of a shagged cylinder and I have a set of T5 casings ready and waiting.
there are some 125mm + rods ive found or a different piston crown height could help you achieve the build
OzOAP
Would be interested in the long rod rather than 'long' piston route.
Won't ask you to tell me what the long rod is from, but how much you would supply one?
Looking at starting a project in the new year. Got a garage full of Vespas, and havn't built anything new for 6 years!
grimspeed
Main scooter: gp 283 kx
I take it it was a rotax rod you used ?
could you go up to a 24mm pin and use a steped pin 22mm-24mm?
Like martin is using on my 68mm stroke Lamby crank .
mick1
Main scooter: Li Avanti 225
There was a set vespa 200 casings on e-bay a couple of weeks ago. Modified to take a TS1 etc...
