Vespa P177 project
Ivan_200
Main scooter: Vespa PX125/177
Hello, here's my vespa project:
Started as a white '83 PX125
Partially sanded, primed, welds seamed
Painted in bmws phoenix yellow
Fitted complete fork with disc brake from Piaggio Skipper (SKR), garelli fender with custom bracket, yankee seat, smoked headlight, white rear light, etc
Ivan_200
As for the engine... Casings cleaned, wirebrushed and clear coated, all ports widened
Polini 177 cylinder with widened exhaust port and new asso piston
Banded clutch with stronger springs
Stronger crank bearings, oem cut crank (rotary), oko (pwk) 30mm carb with manifold, simonini exhaust, etc
Ivan_200
Fitted Conti Twist Race tires
And this is how it looks today
:fb:
Minority
Main scooter: Li230 S3
Fair bit of work their, well done!
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
That looks a nice bike, i prefer the hugger mudguard,, are the skipper forks a straight swap or did you modify them,,
Ivan_200
gerryjunior wrote:That looks a nice bike, i prefer the hugger mudguard,, are the skipper forks a straight swap or did you modify them,,
Top of the fork has to be grinded off (it's too long), and new thread cut lower. The lock "slot" is also on a different place.
Very nice, I like it.
