Mitaka Piston Promotion
OAP
Mitaka 70mm piston promotion on until 14th December 2012 1/3 reduction!
Piston ported and Oval window reed valve.
http://www.supertune.co
Minority
Main scooter: Li230 S3
OAP wrote:Mitaka 70mm piston promotion on until 14th December 2012 1/3 reduction!
Piston ported and Oval window read valve.
That's outstanding value Ron!!
lockman69
Any promotions on the 70mm TS1 pistons ?
Ta
OAP
Yes, with the Oval Window, have a look!
lockman69
Doh :oops:
Ta
camel
perfick...just ordered the reed version,cheers
Ron, which of the TS1 pistons, Oval window or dual window, would suit the Avanti kit best with a reed valve?
lockman69
Hello Ron...I did send this question to your web site but did not receive an answer?
Are there any advantages or disadvantages to an Oval window as opposed to a regular window?
My head has been profiled to suite an Asso/RT (?) piston, would this piston be a suitable replacement?
Thank you.
OAP
Quote: Ron, which of the TS1 pistons, Oval window or dual window, would suit the Avanti kit best with a reed valve?
Martin, Neither! Kit pistons are different, I can get one machined up though.
Speed Demon
Hi Ron - why are you selling all these off cheap - just to get them moving or any other reason?
Sticky
Get to SULK
