Clutch problem
noggin1969
Just fitted my new CamLam 5 plate clutch everything fitted nice and bolted down well. Put engine back together ok. Started it up and ran well until i pulled clutch in and there was a rattle and it stalled , tried it a couple of times with the same results. Try clutch without engine running and clutch works great while using the kickstart or pushing it in gear. Any ideas ?
Has a mind full of useless s**t and isn't afraid to use it !
Sounds like the circlip holding the plates in has popped off.
noggin1969
no thats fine justed checked , only thing i can think is i replaced the spider with an SIL one as recommended at the same time but i can't see any marks if its catching
how far does the spider stick out past the crownwheel it shoud be no more than 0.1mm yes that one tenth of a mm
noggin1969
yes thats spot on , i'm just wondering if the new spider may be splaying upwards as the brass clutch thrust bush pushes onto it or if the clutch flange is doing the same under the pressure of the new springs.
    Users browsing this forum: Semrush [Bot] and 13 guests
