floppy clutch leaver
Tosh
say i ride in traffic for a while and have to keep pulling the clutch in and out the leaver does not
return it stays about 5mm from home,is it weak springs, or is this natural,clutch don`t slip even with my son on back up or down dale,i am some what confused :?:
Muppet
Yer plates is getting hot an theys expanding so you clutch bell sits further in the case makin yer lever slack when it all cools doon yer plates shrinks back to there previous normal size and yer lever is back t wer it came from,
muppet,
C’est la vie
Tosh
thanks muppet for that,it wasn`t that i was getting worried i just wondered if other people go through
the same prob from the same situation.
Ta Paul
Just a thought You havnt just fitted a new cable have you ? this these can sometimes strech after use and need adjustment.
