150 head on 175 conversion
Posted: Sat Oct 13, 2012 5:05 pm
by brianc
hi,what mods are required to a 150 cylinder head for a 175 conversion,
brian.
Re: 150 head on 175 conversion
Posted: Sat Oct 13, 2012 6:26 pm
by Adam_Winstone
Diameter needs to be taken out to 63mm, following the profile of the new piston, then you really need to address the combustion chamber size to give a suitable compression ratio.
Bearing in mind that these are dirt cheap off places like AF, most people just buy new... although you really should check compression ratios anyway!
Adam
