150 head on 175 conversion
brianc
Main scooter: lambretta gp
hi,what mods are required to a 150 cylinder head for a 175 conversion,
brian.
Diameter needs to be taken out to 63mm, following the profile of the new piston, then you really need to address the combustion chamber size to give a suitable compression ratio.
Bearing in mind that these are dirt cheap off places like AF, most people just buy new... although you really should check compression ratios anyway!
Adam
    Users browsing this forum: Semrush [Bot] and 70 guests
