Series 3 engine into series 2 frame.
Posted: Fri Oct 12, 2012 9:35 am
by Ihateyoubutler
Do I need a different kickstart to do this or will the original one off the series 2 engine be ok? The new engine has a gp chaincase if this makes any difference?
Are there any other things that might need altering for it to fit? Not collected the scoot yet (spanish winter model) so trying to plan ahead.
Thanks.
Re: Series 3 engine into series 2 frame.
Posted: Fri Oct 12, 2012 10:34 am
by bristolmod
just fit the S2 kick start and away you go
Posted: Fri Oct 12, 2012 1:04 pm
by RICSPEED
i think the kickstart stop may be to short as the stop on series two case is different .. just need to extend the stop slightly
Posted: Fri Oct 12, 2012 1:36 pm
by Gazbo72
They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
Posted: Fri Oct 12, 2012 2:02 pm
by Toddy
Gazbo72 wrote:They do a series 2 kickstart with a series 3/ GP sidecasing. As Ricspeed says the stop is longer.
Agreed buzzsolomoto does one seems decent quality :D
Posted: Fri Oct 12, 2012 8:37 pm
by Ihateyoubutler
Thanks,as usual,for the help.
Posted: Fri Oct 12, 2012 8:53 pm
by The prisoner
Winter Models did not have already series 3 engine in "a sort of" series 2 frame?
So a "so special" kickstart lever was fitted..?
