The Dyno Process
Posted: Thu Oct 11, 2012 5:15 am
by DigDug
I hope this doesn't sound too daft a question but are the final power dyno runs on a 4 speed manual box carried out in third or fourth gear?
Re: The Dyno Process
Posted: Thu Oct 11, 2012 5:56 am
by Andy Pickering
The ones I've been present at have been 3rd
Posted: Thu Oct 11, 2012 6:52 am
by paulmgreen
3rd........... Will the next question be why???
Posted: Thu Oct 11, 2012 8:17 am
by DigDug
paulmgreen wrote:3rd........... Will the next question be why???
Oh go on then.....
Posted: Thu Oct 11, 2012 9:58 am
by Train Driver
I've used a few dyno's and all used 3rd gear except Simon at B-race
Posted: Fri Oct 12, 2012 10:50 am
by Sonny
The 3 main types of runs we perform are :-
AG ( All gear ) this is usually plotted power,Torque & AFR against time
RO ( Roll on ) usually performed from 2000 rpm (ish ) in 3rd and plotted against rpm
FA ( Fast acceleration ) again 3rd gear from 5000 rpm (ish) again vs rpm
All the above should also be plotted against the AFR ( Air Fuel ratio )
The reason we use 3rd as it's an easier gear to use to show peak power over time 1st & 2nd's two quick and 4th too long so 3rd is a happy medium. When we set up the sprint engines for example the final test is always peak power in all gears to help set up gear changes etc . theres lots of other factors involved such as inertia/acceleration/load/gear ratio's/AFR/correction factors etc etc, hope this brief explanation helps.
Pete
Posted: Fri Oct 12, 2012 12:38 pm
by DigDug
Pete
Yes indeed, very much appreciated and thanks
John
