The Dyno Process
Want to chat about dyno result or any other aspect of graphs/power/components....then post here!
DigDug
I hope this doesn't sound too daft a question but are the final power dyno runs on a 4 speed manual box carried out in third or fourth gear?
Did you have to do that?
The ones I've been present at have been 3rd
paulmgreen
3rd........... Will the next question be why??? ;)
www.JPPLambretta.co.uk
DigDug
paulmgreen wrote:3rd........... Will the next question be why??? ;)
Oh go on then..... :D
Train Driver
I've used a few dyno's and all used 3rd gear except Simon at B-race
Sonny
The 3 main types of runs we perform are :-
AG ( All gear ) this is usually plotted power,Torque & AFR against time
RO ( Roll on ) usually performed from 2000 rpm (ish ) in 3rd and plotted against rpm
FA ( Fast acceleration ) again 3rd gear from 5000 rpm (ish) again vs rpm
All the above should also be plotted against the AFR ( Air Fuel ratio )
The reason we use 3rd as it's an easier gear to use to show peak power over time 1st & 2nd's two quick and 4th too long so 3rd is a happy medium. When we set up the sprint engines for example the final test is always peak power in all gears to help set up gear changes etc . theres lots of other factors involved such as inertia/acceleration/load/gear ratio's/AFR/correction factors etc etc, hope this brief explanation helps.
Pete
If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man.
DigDug
Pete
Yes indeed, very much appreciated and thanks
John
