Advice about crack in casing
The prisoner
Main scooter: Serveta Jet 200
Evening all.
Could you tell me honestly what you think of this crack in casing before i go further in rebuilt?
Cheers.
It's located under cylinder on the mag side:
This one is too clear but just to show you how deep it is:
And with the bearing flange just beside:
An adult could help ;) ?
The prisoner
eden wrote:dam, i thought this topic was going to give some advise on smuggling crack :(
what a shame :lol:
:lol: i can give you an advice on how to repair a casing with tooth-past but not sure it's a good one...
I would just grind it back so there is less chance of a piece braking away.
Will do a picture with some marks where i intend to grind it, you'll tell me if it's enough or too much ok?
Cheers.
a.lo.v2
Main scooter: sx 200
a casing i have has a section there removed, obviously someone previously has had to lever out the seal plate.
Minority
Main scooter: Li230 S3
The prisoner wrote:It's located under cylinder on the mag side:
Just to avoid any confusion, that is "drive" side not "mag" side isn't it?
Chris CSPE
Nothing to worry about, it's just a thin part of the case that won't prove a problem.
paulmgreen
Yes as above. Nowt to worry about
www.JPPLambretta.co.uk
The prisoner
Eden, is it enough?
Or do i go further in grinding 'till the black line (just to remove the mark in casing still visible)?
Cheers for all your quick advices.
