imola jetting
cee
Main scooter: vespa parmakit v100
hello all
is there anyone on this forum who has the same setup as me, and who is able to give me a quite close jetting setup?
setup
imola 186 plug and play
jl3 curley
phbh 28
lth short manifold
many thanks
cedric
Craig H
Mine is similar
Carb settings are:
122main av266 atomiser x7needle 2nd clip from top 55 pilot 40slide JL3 casings have extra alloy around transfers to be able to match the kit
cee
Thanks! What do you mean with jl3 casjngs?
Are you also running it with a sacch
i filter?
Craig H
Sorry it has a JL3 exhaust and the engine case has extra ally added to the transfer area so they could be made bigger to match the kit and no air filter being used
