Help with a repair in N. London/Herts please
ukoldschool
Can anyone reccomend somebody local (ish) to repair my hub please? It needs a crack welding up and a reverse thread helicoil fitted :baddevil:
If now local then is there somebody trusted I could send it to for repair?
cheers!
as a welder i wouldnt touch someones hub, ive been asked to weld disc hubs in the past and refused what hub is it
ukoldschool
Original inboard disc, window side. small hairline crack where the remains of a stripped hub stud refused to come out.. I was thinking a simple slot through the crack then weld up and I could shape it to suit? then get a helicoil fitted afterwards. The actual lug is still exactly as before.
Daggs
Instead of faffing about with a left-handed helicoil, if such a thing exists.
How about welding up the crack and hole (ooh errr!!!) then redrilling and tapping it. Possibly to take a standard 8mm setbolt.
I know it won't look pucker, but it may well be stronger.
ukoldschool
hmmm.. clearance problems on the rear?
Timbo
I know a top class welder at Letchworth, scooter man.......
monkey boy
Why not use the press fit studs??
Gotta be easier than trying to sort out the thread..
MB sell them
CHEERS AL
