Can anyone reccomend somebody local (ish) to repair my hub please? It needs a crack welding up and a reverse thread helicoil fitted :baddevil:
If now local then is there somebody trusted I could send it to for repair?
cheers!
Help with a repair in N. London/Herts please
ukoldschool
- registered user
- Contact:
as a welder i wouldnt touch someones hub, ive been asked to weld disc hubs in the past and refused what hub is it
ukoldschool
- registered user
- Contact:
Original inboard disc, window side. small hairline crack where the remains of a stripped hub stud refused to come out.. I was thinking a simple slot through the crack then weld up and I could shape it to suit? then get a helicoil fitted afterwards. The actual lug is still exactly as before.
Instead of faffing about with a left-handed helicoil, if such a thing exists.
How about welding up the crack and hole (ooh errr!!!) then redrilling and tapping it. Possibly to take a standard 8mm setbolt.
I know it won't look pucker, but it may well be stronger.
ukoldschool
- registered user
- Contact:
hmmm.. clearance problems on the rear?
- monkey boy
- registered user
- Contact:
Why not use the press fit studs??
Gotta be easier than trying to sort out the thread..
MB sell them
CHEERS AL
MB sell them
CHEERS AL
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 4 guests
