Indicator warning light
Richard
Just put a new loom into my P200E, old one was crumbling also had serious headlight flashing when indicators were switched on. All seems o.k. now except that I can't stop the indicator warning light from flashing even when indicators aren't on. Tried another switch & flasher relay but still the same so it must be how I've wired up to the headlight. Anyone got an idea as to where I have gone wrong?
Richard
Muppet
Richard wrote:Anyone got an idea as to where I have gone wrong?
Richard
Yep, ya got a Vethpa, ;)
C’est la vie
Richard
Yeah I know and their electrics are infamous......
gaz_powell
do you want i wiring diagram sending ?
pm your email address if you do
gaz
Richard
Sorted..... sort of.
The speedo light harness had two joined earthing wires for the idiot warning lamps. These had to be separated reclamped & then put back into different clips on the bulb holder,still have a spare grey wire which seems redundant, just need to wire in front brake switch, fit new exhaust then M.O.T. time.
GP240
spare grey - horn ?
Richard
GP240 wrote:spare grey - horn ?
Wired up front brake to this grey and it works. Seems that this must have been added into loom as I ordered the front brake switch & wiring at the same time,nice to get something that works as it should.
