Brass clutch plunger.
Posted: Fri Sep 28, 2012 8:22 pm
by 10 inch Terror
Hi all, does anyone know roughly how far the brass plunger on GP sidecasing pushes in when the clutch is engaged? I need to do a few measurements before i install a clutch. Thanks in advance Pete.
Re: Brass clutch plunger.
Posted: Fri Sep 28, 2012 8:31 pm
by RICSPEED
7mm/8mm roughly though that is with case off mind
Posted: Fri Sep 28, 2012 8:38 pm
by 10 inch Terror
RICSPEED wrote:7mm/8mm roughly though that is with case off mind
Ok thanks. I'm about to fit a clutch and i'm a bit worried it will go coilbound, as there doesn't appear to be much space in there. I've fitted an AF clutch before and the springs seem almost fully compressed and it was fine, so i'm sure it will be ok.
