mounting the pickup for a sip digi speedo
Davidsquaredson
Main scooter: Early Eibar Jet 200
hi,
Wondering if anyone could post a pick of how they mounted the magnet and pick up to get the sip digital speedo to work. I,ve got an early scootrs outboarddisk and its never been accutrate. The worm gear is a mess and they have changed the design. Just got did for speedingfor second time this summer, price of the fines way more than a new digital speedo. Want to be sure i can mountit before ordering.
Tx in advance
David
carpe scooter diem
1974 Rally 200
1965 Li150
1963 TV175
1974 Eibar Jet200
Muttlyoo7
Main scooter: Gp200
If you look here you'll find all the stuff you need to use a pick up on a SIP speedo. :D
http://www.sip-scootershop.com/en/produ ... obi002s08n
There was a feature on these speedos in Scootering a couple of months ago with a picture of the sensor fitted to a Lambretta.
Minority
Main scooter: Li230 S3
This is how I've just mounted mine.
With the active pickup you don't need to use a magnet (so I'm told)
A couple of pics of the bracket I made up to hold the sensor for my new SIP speedo.
I decided to "pick up" from the studs on the rear hub and I'm quite happy with how the bracket looks.
I've just got to drill and tap for a couple of grub screws and give it it's final polish and it will be finished, just hope it all works ok!
