1st gear ratio
camel
having a little difficulty pulling off from standstill and its a nightmare on a hillstart,a lot has to do with my stiff clutch which im going to revisit(as it has a centre spring)
the question im asking is...is my first gear ratio to tall to be usable?im running a pacemaker box 19x46 with a final ratio of 4.45..its pulling
through the gears nicely using a ads 3....its just take off im stuggling with,running the 19 front i appreciate ive shifted all the ratios higher...so my 1st is now..11.02...
