PX problems
Posted: Thu Sep 13, 2012 8:17 pm
by simon lee
I have a problem with the indicators on my 1985 px. The front ones dont work at all and the back ones come on but want flash, any ideas ?
Re: PX problems
Posted: Thu Sep 13, 2012 9:01 pm
by fraserp200e
Try another flasher unit, sounds like its knacked.
Has the fault just appeared or have you just rebuilt the scoot?
Re: PX problems
Posted: Thu Sep 13, 2012 9:11 pm
by lambro
Check front bulbs,
Check front earths,
I am sure back wont flash if fronts don't work.
Then unscrew the indicator switch and make sure all 6 wires are still soldered on.
Then head relay area.
Shaun.
Re: PX problems
Posted: Thu Sep 13, 2012 9:31 pm
by simon lee
Thanks for the replys will do some checks tomorrow, they were working but both fronts stopped working at the same time yesterday
Re: PX problems
Posted: Thu Sep 13, 2012 9:35 pm
by Muttley McLadd
Could be something as simple as a wire off in the switch. That's an easy check too :)
Re: PX problems
Posted: Fri Sep 14, 2012 8:47 am
by fraserp200e
Remember to post up when you find the snag. It'll help others out when they have a problem and are searching the forum for the solution ;)
Re: PX problems
Posted: Fri Sep 14, 2012 8:59 am
by gaz_powell
Every problem i`ve had with indicators has been in this order :-
1. broken wire on switch
2. bad earth
3. crap in panel socket
4. Bulb
5. Switch knackered internally
6. Flasher
best of luck !
Re: PX problems
Posted: Sun Sep 16, 2012 5:18 pm
by simon lee
Now sorted thanks for all the advice it was the flasher unit
