PX problems
simon lee
Main scooter: Vespa PX 125
I have a problem with the indicators on my 1985 px. The front ones dont work at all and the back ones come on but want flash, any ideas ?
fraserp200e
Main scooter: 1988 MotoVespa TX200
Try another flasher unit, sounds like its knacked.
Has the fault just appeared or have you just rebuilt the scoot?
1983 Vespa PX125
1984 MotoVespa P200E
lambro
Check front bulbs,
Check front earths,
I am sure back wont flash if fronts don't work.
Then unscrew the indicator switch and make sure all 6 wires are still soldered on.
Then head relay area.
Shaun.
simon lee
Thanks for the replys will do some checks tomorrow, they were working but both fronts stopped working at the same time yesterday
Could be something as simple as a wire off in the switch. That's an easy check too :)
fraserp200e
Remember to post up when you find the snag. It'll help others out when they have a problem and are searching the forum for the solution ;)
1983 Vespa PX125
gaz_powell
Every problem i`ve had with indicators has been in this order :-
1. broken wire on switch
2. bad earth
3. crap in panel socket
4. Bulb
5. Switch knackered internally
6. Flasher
best of luck !
simon lee
Now sorted thanks for all the advice it was the flasher unit
