Page 1 of 2
Ram Air Filter
Posted: Mon Aug 27, 2012 1:18 pm
by Shuggie
Looking for a ram air filter for a jetex 22 carb , what size do i need and anyone know where to get them?
Re: Ram Air Filter
Posted: Mon Aug 27, 2012 6:55 pm
by camel
fleabay do various sizes for lambretta if you care to measure your own carb....but if you have a std carb why not use the airbox?do you want the ram air to bolt to your carb or on the rubber bellow/elbow?...
Re: Ram Air Filter
Posted: Tue Aug 28, 2012 8:44 am
by Shuggie
using it on a chop and my mate is building the engine just now so havent got carb to measure! was hoping someone might know offhand what size i needed, i'll get over at weekend and measure it then. cheers
Re: Ram Air Filter
Posted: Tue Aug 28, 2012 9:51 am
by rosscla
If its the same as a standard sh22. Then the fitting is about 44-45mm
Re: Ram Air Filter
Posted: Tue Aug 28, 2012 3:02 pm
by corrado
I'll see what I've got that'll fit. Should have the "MB" type Ramair that's fitted to a GP200 airhose. I've got different sized Breath Sweet filters too but I'll need to do a bit of measuring to see if there's one small enough for a Jetex. May have some that bolt straight onto the carb to but I think the general opinion is that these don't work as well as having some distance between carb and foam?
Re: Ram Air Filter
Posted: Tue Aug 28, 2012 3:03 pm
by corrado
Should have these too ...
They come with a few adaptors in different sizes. I'll check what I've got. Had some Black ones too.
Re: Ram Air Filter
Posted: Thu Sep 06, 2012 2:49 pm
by Shuggie
got one ordered from Readspeed........will find out how well it works shortly!!!!
Re: Ram Air Filter
Posted: Fri Sep 07, 2012 1:50 pm
by corrado
Re: Ram Air Filter
Posted: Fri Sep 07, 2012 2:55 pm
by Shuggie
bummer............i'd have took the one in the 4th pic , looks ideal.......i'll see how it runs with the readspeed one
Re: Ram Air Filter
Posted: Fri Sep 07, 2012 6:58 pm
by Timbo
Martin 3rd down, the red one. Can I have one for a 22 delly please.
